Isuzu Rodeo damage code
13 years 7 months before #32618 by manual-mecanica
Isuzu Rodeo damage code published by Manual-Mecanica
Greetings friends, I made a scan to the Isuzu that I have and I got the following codes of damages
P1125, P1295, P1515, P1516, P0300, P0401.
Looking for this interpretation:
P1125 etc (electrical control of the intake valve) The limit performance mode
for me has to be some broken or disconnected vacuum tube, or some hose of the punctured admission, poorly connected or with an air leak.
The P1125 code is recorded when the turbo pressure control solenoid fails to control turbo pressure. That may be because it does not get empty to the Wastegate valve, or because there is a pressure leak in the admission.
1295 The accelerator position sensor does not seem to be receiving enough electricity.
P0300 Motor ignition failure
0401 Exhaust gases (EGR) Insufficient flow
P1515 Current position against commander of the admission butterfly (PCM)
P1516 Current position against the command of the admission butterfly (CT module)
This correct information. I hope you can help me, since the times and consulted in this forum and received the necessary help and thanks to you and solve my problem. Once thanks from a grateful user. Greetings to cumune. Edwin
