VW TRANSPORTER Power problems
13 years 7 months before #32606 by manual-mecanica
VW TRANSPORTER POWER PUBLISHED BY MANUAL-MANICA
I have a VW Transporter 2.5 TDI year 2001. The turbo reaches 0.6 bar at 3500 laps and then falls to 0.4 bar and loses strength. Which may be the problem.
13 years 7 months before #32619 by manual-mecanica
Manual-Mecanica Response on the Re: VW TRANSPORTER PROBLEM POWER
Hello, as checked if you have any leak or you get the yellow engine symbol, if you have a leak you may save the turbo or the flow that usually fail
13 years 7 months before #32620 by manual-mecanica
Disconnect the air input hose to the turbo and inspect the alaves looking through a mirror, it can be k is stuck because there is no other, just change the turbo
13 years 7 months before #32645 by manual-mecanica
I'm very sorry, that is called € 300 pasta
