Consultations
13 years 7 months before #32545 by manual-mecanica
Consultations published by Manual-Mecanica
I have a VW Golf 2005 presents a small jaloneo check it with Scanner and a large list of p0300 codes, P0301, P0303, P0304, P0116, and the P0420, and the P0420 before this changed the coil and the spark plugs since from one moment I stopped starting and changing the coil and removed that fault but after three days the focus was taken Marco codes, me inconsistent by throwing so many codes that record. I don't know where to start with someone, someone helps me. THANK YOU
13 years 7 months before #32548 by manual-mecanica
Manual-Mecanica Response on the Re: Consultations
First you must erase the codes (some are from above problems) and then handle your vehicle so that the computer detects the real problems.
