Reset pilot motor failure in Renault Clio 2003
13 years 7 months before #32483 by manual-mecanica
Reset pilot motor failure in Renault Clio 2003 published by Manual-Mecanica
Good I had an injector problem in a 2003 result clio, I have changed them and the car is now perfect but the damage indication pilot in the engine is still on, is there any way to reset it? More than anything is because of the pain that already gives part in case any fault that tells me before something more serious occurs
thanks to everyone and greetings
13 years 7 months before #32485 by manual-mecanica
To reset the control unit of this vehicle you should only disconnect the negative battery line for about 30 seconds, thus erase the data stored in RAM.
It would be very good anyway to connect the scanner to verify if it has a fault code, generated by a sensor or actuator. The diagnostic connector of this vehicle is located on the console under the ashtray, is 16 -pin traitation type connector.
13 years 7 months before #32531 by manual-mecanica
Thank you very much I will try the battery since I do not have the program or the cable, it is but I do not know where to get it
a greeting
13 years 7 months before #32544 by manual-mecanica
In a workshop where they have this tool and know how to interpret it can give you a successful diagnosis.
