Problems with Daewoo Cielo
13 years 5 months before #32399 by manual-mecanica
Problems with Daewoo Cielo Published by Manual-Mecanica
Hello, my friends, friends I told you 2 months ago I made a general engine repair, I changed rings, rings set, packaging, t -shirts, rectifying those of Bancaday Liela, new piston and the valves what turned out the fault the cylinder one did not work the medium compression Bajisimo Bueno I took out the piston and found it the two comprehecious comprehecious rings aliniad 4 cyl. Well but after a week I get the same problem the cyl, one does not work compression well low ... what I think may be that the rings have been alinated again and more cylinders are low, my questions are low is ..... by the rings they get to alinent tanrap ....... I will appreciate it.
13 years 5 months before #32401 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with Daewoo Cielo
Hello, the hoops rotate and the alignment of them is very unlikely, you should check the rectification of the cylinders that the work and slack of the piston is done well in the shirt, also strike the slot of the hoops with the hoops, light of rings.
13 years 5 months before #32402 by manual-mecanica
Hello, I do not think your problem is the bad distribution of the rings in case the flies check the manual and check the Solguras in that cylinder and the ring game with the piston channel.
13 years 5 months before #32407 by manual-mecanica
Probably require the rings to another extent, or even the piston, you would be a matter of measuring it exactly with precise tool to draw conclusions.
13 years 5 months before #32414 by manual-mecanica
Hello, as the other friends already tell you, try before the rectified Loko becomes
