Peugeot 206 the engine turns but not part
13 years 8 months before #32276 by manual-mecanica
Peugeot 206 The engine revolves but not part published by Manual-Mecanica
I have peugeot 206 engine 1.4 year 2001 the engine rotates but not part. If anyone knows what problem can have
13 years 8 months before #32280 by manual-mecanica
Manual-Mecanica response on the Re: Peugeot 206 the engine rotates but not part
Check if there is gasoline in the injector rail, if there is review that the injectors work.
also check if there is a spark
13 years 8 months before #32283 by manual-mecanica
In general, if it is not a 20 ampers fuse that is in the inner rifle and that is different from all of all with orange, if I remember correctly, it could be that the computer is blocked or the magnet captor checks as Othoniel says if what is missing is fuel or spark Impact that is on the left pillar of the shock absorber, but check first than missing to help you better.
13 years 8 months before #32289 by manual-mecanica
Thank you estimated, I'm going to check out the possibilities that have given me, hopefully one of them.
