Nissan Sentra 98
13 years 9 months before #32054 by manual-mecanica
Nissan Sentra 98. Published by manual-mecanica
I have a problem with my vehicle; it's consuming oil, but it's not leaking anywhere. I add a quart every four days. There are no stains on the engine, and it doesn't leave any residue on the ground in the morning. If you could give me any tips on how to find the cause,
I'd appreciate it. Thanks in advance.
13 years 9 months before #32060 by manual-mecanica
Manual-mechanics' response on the topic Re: Nissan Sentra 98
Have you noticed if it's emitting blue smoke from the exhaust?
13 years 9 months before #32137 by manual-mecanica
Take out the spark plugs and check their color. If they are black and have hard scale, then it's either the piston rings or the valve stem seals. Obviously, it will emit blue smoke, as Otho says. If it doesn't, then the problem is somewhere. Anyway, you're adding a lot of oil, so it must be somewhere.
