Problems with a radiator sleeve
13 years 5 months before #31969 by manual-mecanica
Problems with a radiator sleeve published by Manual-Mecanica
Hello to see if someone throws a hand the little sleeve of the radiator is fast -hooked that they call his fucking mother, because he enters and tracking little by little he does not give up or pussy someone knows any trick to make it simpler or if you have to first put the rubber washer thanks
13 years 5 months before #31979 by manual-mecanica
Manual-Mecanica response on the Re: problems with a radiator sleeve
First put the rubber washer then fit it
13 years 5 months before #32175 by manual-mecanica
Thank you very much to be able to try my
13 years 5 months before #32178 by manual-mecanica
ok greetings
13 years 5 months before #32180 by manual-mecanica
Look at some radiators that sleeve has an orrin and balloons and then toured it and is sometimes losing veil
