MEGANE HOSE WATER BOAT PROBLEMS
13 years 8 months before #31966 by manual-mecanica
MEGANE HOSE WATER BOOT Problems published by Manual-Mecanica
Good afternoon, my automatic renault megane
is throwing water through a hose, turns off the air to condition and the cary stops throwing out but when the car is turned on without the air begins the water boat again, the hose is behind the engine, to which that water boat is owed, I need your help please
13 years 8 months before #31967 by manual-mecanica
Manual-Mecanica response on the Re: problems with megane hose water boat
You might have a broken maguera or a lazy clamp takes it to a trusted mechanic
13 years 8 months before #31987 by manual-mecanica
Manual-Mecanica Answer on the Re: problems with mega hose water boat
Replaces the hose, the problem you have is normal, since over time the hoses are split, harden or small fissures are made where the antifreeze.
Repair it immediately and check the antifreeze level to prevent your car from overheating.
