Motor operation problems.
13 years 8 months before #31829 by manual-mecanica
Motor operation problems. Posted by manual-mecanica
Estimated,
Tngo problems with my Subaru Legacy year 90.
When starting it does well, but after 1 to 2 minutes it begins to lower the revolutions to the point of stopping, it has been done cleaning and change of repair in the carburetor (only that), I need your help.
Thanks in advance.
13 years 8 months before #31850 by manual-mecanica
Manual-Mecanica response on the Re: Motor operation problems.
Rigo Everything good calculates that if it starts well and after a while we are talking that some feet takes temperature to which it does not do everything material when taking temperature is expanded that if the problem is mechanical (carburetor base, valve seats I am valve etc.) This can produce failures in adm or crystallized the internal gel to which it ceases to be protected against heat and a current cut or failures occurs when walking in some cases it usually happens with the thiss of Esteido fix and let me know but we are looking for the return SLDS
13 years 8 months before #31851 by manual-mecanica
When you see the MSJ let me know and tell you how to try the probabilities that told you. by
13 years 8 months before #31919 by manual-mecanica
Ok. I have read Atte. The comment
waiting for indications ...
Atte.,
Rigo
13 years 8 months before #32022 by manual-mecanica
I forget to indicate that the engine is with electronic touched.
