MEGAN AIRBAG LUZ PROBLEMS
13 years 8 months before #31817 by manual-mecanica
MEGANE LUZ AIRBAG Problems published by Manual-Mecanica
Hi, I'm new in the forum and I would like if someone can tell me how to change the airbag ring of a megane 2 since I have downloaded the manual and I do not find it if someone can help me I would appreciate it
13 years 8 months before #31818 by manual-mecanica
Manual-Mecanica Answer on the Re: Luz Airbag Megane Problems
Hello, you are sure that it is the ring that fails
13 years 8 months before #31819 by manual-mecanica
It seems that it is a problem that the Service Light and the Airbag are usually on and something sounds in the steering wheel when it is changing all the controls of the flashing ones that everything must come together
13 years 8 months before #31820 by manual-mecanica
13 years 8 months before #31821 by manual-mecanica
First of all: you have to diagnose the breakdown with a diagnostic team, if you give you the failure I see well that you want to try to change your foot, but from experience I tell you that you assure yourself, if you do not leave you have spent a money.
