Volkswagen Vento part and stands
13 years 8 months before #31771 by manual-mecanica
Volkswagen Vento part and stands out by Manual-Mecanica
Hello friends, my Volkswagen Vento 98 car starts and the engine stops, other times the engine does not start, it only turns, sparkle arrives in the spark plugs, fuel arrives at the injection ramp, the setting is fine, it reaches food to the coil, and I don't know what else to do, for your help thank you very much thank you very much
13 years 8 months before #31772 by manual-mecanica
Manual-Mecanica response on the Re: Volkswagen Vento part and stands
Hello friend, you would have to try disconnecting the escape, sometimes the catalyst is usually plugged or crumbled ... greetings ... greetings
13 years 8 months before #31776 by manual-mecanica
I think the fuel pump pressure should be measured, it is possible that the pressure valve is failing
