Ford Fiesta Radio 95
17 years 6 months before #3171 by manual-mecanica
Radio Fiesta del 95 published by Manual-Mecanica
Hello everyone, I have a Ford Fiesta del 95, because the radio CD reader was not going to change it for another, thinking that the previous owner would have already put the ISO connectors, but no.
Total that there was a quite elegant fuck of cables, I went to buy the connectors but when going to be pair with the two cables that were cut to spliced ​​the other radio did not go, and that I tried to despair with all the cables.
The weirdest thing is that the antenna cable sparks when trying to put: S
my question is:
if the first two cables are cut from the old connector, which are the ones that have to spliced? And something else when jumping sparks I do not know if I would load any fuble, on the left side below I have the fuse box which one that goes to the radio?
Thank you very much to all and forgiveness for the rollazo, but I walk with all cables on the outside and without a radio torture!
KISSES
17 years 6 months before #3196 by manual-mecanica
Manual-Mecanica Response on the Re: Radio Ford Fiesta del 95
Hello Ruth, first it may be that you have loaded the fuse of the radius or the car in the lid or in the owner's manual tells you what is the separate fuse that is seen which is the burning after the sparks are strong or weak because if the radius is strong or connected the cables to the setbacks and if they are weak it may be normal because the radio also takes the antenna. Radio with the instruction or in the connector that you bought should bring something indicated that normally brings it if you do not let me know that I explode it step by step greetings Alfredo.-
