JCB 804 super miniexcavadora
13 years 8 months before #31700 by manual-mecanica
Miniexcavadora JCB 804 Super published by Manual-Mecanica
Hello.
I have a mini excavator JCB 804 Super and the chains do not work well, take out the hydraulic pumps and take them to check and do well. What can be the breakdown?
GREETING JOGARNI
13 years 8 months before #31706 by manual-mecanica
Manual-Mecanica Answer on the Re: Miniexcavadora JCB 804 Super
If the pumps are well, check the arrival of pressure to the traction engines or take out the small hose of an engine and look at the oil that falls through it and so with the other thinks that it cannot fall much put a bucket or bottle and with a watch look how much cahe (1 minute)
13 years 8 months before #31717 by manual-mecanica
Hello good night I do not know that specific machine but you do have the hydraulic scheme you should measure pressures to find the breakdown. Also check the electrovalves that command those chain engines.
13 years 7 months before #32744 by manual-mecanica
Hello, we good days thank you very much for the information since the fault came from the distributor where the electrvalvula are long and short, since it had a damaged antiretorne
Jogani
