Change of a 94 Monza
13 years 10 months before #31628 by manual-mecanica
Changing the transmission on a 1994 Monza. Posted by manual-mecanica
I own a Monza GL 1.8 EFI (original gasoline engine).
My problem is that the gearbox is malfunctioning.
Reverse gear won't engage at all, nor will second gear. First gear is currently stuck in reverse.
I need to know what's wrong and what the solution is. Can I fix it myself, or do I need a mechanic? Thanks in advance.
13 years 10 months before #31640 by manual-mecanica
Manual-mechanics' response on the topic Re: Changing a '94 Monza
IS IT AUTOMATIC OR SYNCHRONOUS?
13 years 10 months before #31643 by manual-mecanica
The transmission is synchronous. I need a clear explanation. If I can fix it myself, please tell me how, or if you have a workshop manual or anything that could help me. Thank you for now
13 years 10 months before #31644 by manual-mecanica
First you will have
to tell us if that happened before we intervened or suddenly.
13 years 10 months before #31646 by manual-mecanica
No, I haven't touched it yet.
I bought the car used not long ago, and it started having problems recently. I needed it for work, so I kept driving it. At first, all the gears worked fine. Occasionally, reverse wouldn't engage, but all the others worked more or less okay. Now they don't.
I like to ask questions first before doing anything myself. When you don't know something, it's best to ask and find out, then act. Thanks, I hope you can help me.
