Solved Power Lost Topic
13 years 8 months before #31607 by manual-mecanica
Solved Power Lost Topic Published by Manual-Mecanica
: Cheer: Hi Foros finally I have power, it is afraid of fear and blows the lobito it shows, which goes as it had to go.
Now the time for the explications is. I hope it helps you.
1º-To start as I have been saying the initial problem was change of the Board of Eculata because it was annoyed, a complete rectified and decarbonization of the entire system was made to the car.
2nd adjustment of the pump strap because the previous owner the draft he had was of a tooth of less than competing for
the pump.
4th boxer check OK
5th Valvules OK
6th only the turbo is left !!!
7th Remove turbo and surprise !! Turbo Blocococus of disintegrated admission. Turbo cluster 120 euros. (This price is colleague price)
8th Test -in effect as a Untiro it shows that the revolutions at one point There is an evolutionary leap.
Thank you very much to you have lent me an idea.
