Renault Megane Scenic Disel 1.9 dci
13 years 10 months before #31589 by manual-mecanica
renault megane scenic diesel 1.9 dci Published by manual-mecanica
I have a problem. My car's timing belt broke. I understand that if that happens, the engine is beyond repair because they're interference belts. My question is, what other engines can I install besides the exact same model it came with? I downloaded the manual from this page, but I can't figure out if I can install a different one
13 years 10 months before #31635 by manual-mecanica
Manual-mechanics ' response on the topic Re: Renault Megane Scenic Diesel 1.9 dCi
Hi jjgarcia.
I don't know why you say the engine is finished if the timing belt breaks. As far as I know, the damage caused by the broken belt is repaired, a new one is installed, and the engine continues as before the damage. It's best to get another mechanic's opinion.
Miguel
13 years 10 months before #31648 by manual-mecanica
Good night Jjgarcia as Servilimit tells you the damage caused by the breakage of the belt and ready keep in mind the origin of the breakdown. This is always cheaper than changing the full engine.
