Negative Pulse Problem in ESTEM injectors
13 years 10 months before #31392 by manual-mecanica
Negative Pulse Problem in Injectors Esteem published by Manual-Mecanica
Good evening my case is the following I have a Chevrolett Est this year 2001 year, all the following pears were changed: straps, tensioner, coils, cam and crankshaft sensors, admission and escape valves, gasoline filter, apart from that, in that was done injectors and all were ok, but the problem persists when Injector 1 and 4 The injectors 2 and 3 arrives negative, I do not know what to do because the computer does not turn on the light of check Engine I download the workshop manual and put the cam and the crankshaft ready but nothing the two injectors still do not receive current
13 years 10 months before #31393 by manual-mecanica
Manual-Mecanica Answer on the Re: Negative Pulse Problem in East Injectors
Check the computer or test with another and you will see that your problem is solved
13 years 10 months before #31394 by manual-mecanica
Here in Maracay you get but look for another car and try it with another car and you will see
13 years 10 months before #31397 by manual-mecanica
Hello friend, before exchanging the ECU isgurate that none of the cars have immobilizer, since if so you will not have a car with problems but 2.
I do not know that model, surely it is American, and surely it has an injection of the Multec, and ignition without a distributor, (that is multiple coils) if it is so notice if the coils of the cylinders that you have a negative pulse.
If you do not arrive, you have problems in the ECU.
To rule out, I would remove the ECU and from the pinera I would measure if the missing injection pulse comes (with the connected injectors) and control the continuity of the cable, it can be cut or with a loose connection.
13 years 10 months before #31404 by manual-mecanica
I even disarmed the computer and there is no integrated or anything burned or cold oscare
