2003 Liberty Consultation
13 years 8 months before #31384 by manual-mecanica
Consultation of Liberty 2003 published by Manual-Mecanica
I have a problem with a 2003 Liberty 3.7 I have a P0320 code I already changed the crankshaft sensor and check all the lines of the crankshaft and tree sensor without finding any fault the problem I have is that after starting approx about 15 minutes it goes out and does not start until it cools again again again. When it does not start if you have pulses in the injectors as in the coil. My big doubt because I don't know what to do and my question will be the computer or coil condenser. Can someone help me ????????????? THANK YOU-
13 years 8 months before #31385 by manual-mecanica
Manual-Mecanica Response on the Re: Liberty Consultation 2003
Hello friend X What you say your problem has in some cables try to check all those connectors and Relex Check the computer connector now before doing all this check if when you go out you work the gasoline pump XQ if you have a pulse in the injectors and the coil checks if gasoline arrives also checks the coil reflex to discate
13 years 8 months before #31387 by manual-mecanica
Greetings Abascal, the code refers to a problem in the engine synchronization signals, in this case they are two sensors that the ECU uses for it, the CKP sensor and the CMP, you already changed the CKP that is that of the crankshaft, you need to check the CMP sensor, the last one tells the ECU that "touches" the piston 1 ignition, check this and tell us. Luck.
