Cavalier gearbox 2.2 Motor
17 years 6 months before #3191 by manual-mecanica
Manual-Mecanica response on the Re: Cavalier gearbox 2.2 Motor 2.2
There was a test that could be done in those cars that was to bridge the AyB connectors of the OBD dam so that the switchboard was diagnosed and by light codes tells you what kind of error it does not know if your car accepts this system but almost all the GM accep ALFREDO.-
17 years 6 months before #3192 by manual-mecanica
Another question did you change? and check the overmarcha cable next to the acceleration body and that goes to the box of reveal greetings Alfredo.-
17 years 6 months before #3193 by manual-mecanica
Friend there are no magueras or broken or disconnected I have already reviewed there is no loss of air ... and it must have a fault code but I have no scanner .. Thank you for interested in my problem I hope you continue helping me .. Thank you ...
17 years 6 months before #3195 by manual-mecanica
Try what I tell you a bridge between the first two connectors of the diagnostic connector and should give you an error code with light flickers to read them is easy to see if you can make it diagnosed and make me know
17 years 6 months before #3197 by manual-mecanica
Ok tomorrow morning I am doing that to see how I am out of the workshop and is closed ... but you could explain better about the bridge you don't know the color of the cables .. ??
