DIRECTION PROBLEMS
13 years 4 months before #31360 by manual-mecanica
Problems with the address published by Manual-Mecanica
Hello friends I have a problem with the direction of my car always pulls the direction to the right and led to the alignment and balancing and reviewed wheels and the problem persists; If any of you tubed the Toyota Corona Workshop Manual of 83 with 3T engine
13 years 4 months before #31361 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with the address
But it is when braking
13 years 4 months before #31396 by manual-mecanica
It is not when it stops it is always driving to the right when you go straight
13 years 4 months before #31421 by manual-mecanica
The wheels are totally free the perfectly the same tires distance between the rear wheel and the same as the same as a smoke
13 years 4 months before #31427 by manual-mecanica
Check the damping base
