Changing rear brake pads on a Mitsubishi Eclipse
13 years 10 months before #31293 by manual-mecanica
Hi, I need to change the brake pads on a '98 Mitsubishi Eclipse. I won't need a brake piston tool, will I? I was told I could do it with a carpenter's clamp. Does anyone know anything about this? Or how can I secure the piston with a screwdriver, applying pressure? Thanks, regards.
13 years 10 months before #31329 by manual-mecanica
Manual-mechanics' response on the topic Re: Changing rear brake pads on a Mitsubishi Eclipse
And do you know if this car has the handbrake on the rear calipers?
