I have a 2002 Daewoo Matiz. The problem started with an apparent fuel injection failure, along with the service light coming on until it went off and wouldn't come back on. After it went off, I tried turning the ignition switch on and noticed the fuel system relay making a clicking sound while the switch was on. Another odd thing is that with the switch on, the service engine light doesn't come on, and the same clicking sound is heard coming from the fuel pump. Because of this, I decided to replace the fuel system relay, but the problem persisted. Then I removed the fuel pump and replaced the fuel pump assembly, but the problem continued. Next, I started bypassing the current at the relay contacts, and the pump primed perfectly when I turned the key. Sometimes it would even start, but... whenever I accelerate, the service light comes on again, and the fuel flow becomes erratic until it stalls. I've been told it's a bad ground connection, but that doesn't seem to be the problem. The main safety issue is that when I push it, or in other words, accelerate, it malfunctions and shuts off... I would be forever grateful to anyone who can help me with this, thank you very much in advance.
