Burned rubber
17 years 6 months before #3124 by manual-mecanica
Burned rubber published by Manual-Mecanica
:( Hello everyone,
I have a Jaguar XJ6 of 1990. Recently, has you started smelling rubber or rubber burned when I park after the road. I will be grateful for any contribution.
17 years 6 months before #3130 by manual-mecanica
Manual-Mecanica response on the re: burned rubber
You may have watering oil throughout the engine thanks to leaks of the same or your speed box, you have to wash your engine from the chassis to the top of the engine. You also checked your escape system, it is possible that it is already to be covered or that a few drops of oil is directly the escape system.
17 years 6 months before #3132 by manual-mecanica
Check if you hit a plastic bag in the exhaust pipe sometimes you pass and you feel the smell
