Does not turn on Chevrolet Blazer
17 years 6 months before #3218 by manual-mecanica
Manual-Mecanica Answer on the Re: Does not light Chevrolet Blazer
My good hector I have read what happens to you and I can tell you that you can do what I do when it happens to me to you if you have a spark and gasoline first made a little of direct gasoline to the carburetor that is a monopunto and if it is in a injector by piston I take away an emptiness hose that goes to the plenium and there the gas. Gasoline and I see the pressure since if it goes down, it does not turn on if you think it has a good pressure review the rely and if it does not get a pressure gauge for gasoline I hope I have not confused you luck.
17 years 6 months before #3229 by manual-mecanica
Hey, if I did not euivas more, these bombs were quite a tin, as a little gasoline says, a little gasoline through the mouth of the injector monkey and sees if it turns on, because of the overheating I do not think it is what it can be is that you have the chain of time stretched and you have jumped some tooth the canisa as it was of power when it was?
17 years 6 months before #3250 by manual-mecanica
Thank you Panther,
I will start using the empty manger that you have and there if you manage to start so I think it is the gasoline pump or the pressure regulator.
Thanks again.
