GASOIL PUMP 306
13 years 9 months before #31176 by manual-mecanica
306 Gasail Pump Published by Manual-Mecanica
Good,
my Peugeot 306 diesel pump loses at the bottom, I have been able to find out that if it is disassembled, the joint that produces the escape can be changed.
I have no idea how to do it, would anyone be so kind to guide me?
All the best.
13 years 9 months before #31183 by manual-mecanica
Manual-Mecanica Response on the Re: Gasoil Pump 306
I think that if you have no better idea to leave it ... you would have to disassemble the pump, for that you have to disassemble the distribution, if you have never done it I do not advise you to touch
13 years 9 months before #31187 by manual-mecanica
The problem is that I have already spent a lot of money in the car (clutch, wheels ...) and has more than 200,000 km., So I will not put more money, the options are to give off or give it the last chance, that is to say that I can repair it.
I have investigated around and everything seems to indicate that the bomb is a lucas and is not excessively complicated, take it out to disassemble the side cover that seems to be where it loses to seal the joint.
One day I saw a post of someone who indicated how to disassemble it, but I am unable to meet him.
That's why I ask if someone can guide me about it.
Greetings.
13 years 8 months before #31682 by manual-mecanica
Hi Davali.
The truth is that I have no idea of ​​mechanics, but I find myself in your same situation.
I would thank you for explaining that you have done with the problem, if you solved it and how.
Thank you so much!
Jandro
13 years 8 months before #31683 by manual-mecanica
Do you know how to disassemble the distribution?
