I NEED INFORMATION OF FAULT CODES
13 years 6 months before #31128 by manual-mecanica
I NEED INFORMATION OF FAILURE CODES PUBLISHED BY MANUAL-MANICA
Hello good afternoon I need help of some Renault codes someone knows that they mean 0087 and 0167 If someone has info of these codes, they will be appreciated, they can also occur in Nissan Automatic Transmission DPO Urgent
13 years 6 months before #31130 by manual-mecanica
Manual-Mecanica Response on the Re: I need information codes information
PLEASE PLEASE WHICH VEHICLE YOU HAVE IF IT IS GASOLINE OR DIESEL THE SCOPE YEAR
13 years 6 months before #31131 by manual-mecanica
You must specify a little more if they are codes P, UO P2, usually those codes normally obey problems with idle -led sensors, but you will have to tell us brand, model, year and displacement as well as their fuel to be able to orient you better, greetings and luck.
13 years 6 months before #31132 by manual-mecanica
Renault scene 2003 gasoline engine 4.0
13 years 6 months before #31133 by manual-mecanica
If you know it is that the scanner does not give me P, Uo P2 is why I cannot get them as generic
