Opel Astra cooling problem 1.4 GLS '96
13 years 9 months before #31102 by manual-mecanica
Opel Astra cooling problem 1.4 GLS '9 published by Manual-Mecanica
Friends, I have a problem with my car. Someone could give me where the vulvo of the motor temperature system and motor thermostat is.
The problem is that the temperature of the car rises to the maximum and the car has not really boiled. Could Percan help me? Thank you.
13 years 9 months before #31103 by manual-mecanica
Manual-Mecanica Response on the Rera 1.4 GLS '96 cooling problem
The thermostat is behind the distribution if they are equal to those that arrive Achile, follow the upper radiator hose and there is, and the bulb of the clock is mounted to the butt next to the multiple of admission not from below the distributor or coil that the temperature sensor.
13 years 9 months before #31202 by manual-mecanica
I just read the help. Tomorrow check the data. Thank you! :)
