What is a key to remove cap
17 years 6 months before #3108 by manual-mecanica
What a key to be used to remove cap posted by manual-mecanica
Well, I want to change the oil and I don't know what type of key is that of the Renault Megane plug, have they told me that it is block, but what is the measure?
Thank you very much beforehand.
17 years 6 months before #3119 by manual-mecanica
Manual-Mecanica Answer on the Re: What is key to use plug
You have to make a new key for this uses a 3/8 quadratic increase, reduce it until it squares the hole.
You must use the tool material of any brand but is tempered.
It is lowered with an emery.
Obly if this piece exists but it is special and is very expensive.
17 years 6 months before #3180 by manual-mecanica
Thank you very much, well I went to buy the key, and they told me that it was a square of 8 square, what was said, the oil, oil filter and air filter is changed : Woohoo:
