Spark plugs for Vocho
13 years 6 months before #30971 by manual-mecanica
Vocho spark plugs published by Manual-Mecanica
Hello everyone I have a problem with my vocho is an 80 model but the monoblock is more recent because it has oil filter so I don't know what spark plugs. Can you help me?
13 years 6 months before #30975 by manual-mecanica
Manual-Mecanica Answer on the Re: Spark plugs for Vocho
That I also had a combi with a filter engine and there is not as much difference as without filter I put it Bosch since the VW line was so but they are not platinum but well calibrated and ready I hope I like my suggestion B)
13 years 6 months before #30976 by manual-mecanica
Thank you, my question is that if I can put fuses L12 that are a bit longer
13 years 6 months before #30987 by manual-mecanica
No matter the type of the monoblock or the oil pump, with oil filter, it matters what type of heads they have, if they are heads of an injection vocho carries the N12y or long and if it has carbureted heads it carries the N92y or short
13 years 6 months before #31026 by manual-mecanica
Brasamy is very right, I would first have so much travel when the piston is in the PMS, so that it does not clash and not close it
