SUSPENSION PROBLEM
13 years 6 months before #30872 by manual-mecanica
SUSPENSION PROBLEM PUBLISHED BY MANUAL-MECANICA
Hello, I continue with my Chaparito Jetta, someone who helps me my car is very short of the front and followed the rubber of the left orquit, check the springs and shock absorbers and stop that they are fine but someone who tells me what the height is, with a tire and the spatter, mine does not have more than 4cm?
13 years 6 months before #30876 by manual-mecanica
Manual-Mecanica Response on the subject Re: SUSPENSION PROBLEM
First, what year is it and if you do not notice that you have modifications and I will tell you based on the manual that you can lower it here you can tell you the measures that you need or the user manual
13 years 6 months before #31077 by manual-mecanica
My jetta is 2001 1.8 Turvo, I locompre converted to standard but it was automatic, the detail is very short in front, and followed the rubber of the right orquitable, thanks thanks
13 years 6 months before #31085 by manual-mecanica
You have to review the dimensions of the front of your car and compare them with the factory dice is assumed that the change of box does not affect anything reviews the status of the support of all sides of the engine and body checks the height of the spixture spirals
13 years 6 months before #31088 by manual-mecanica
Hello friend .... You have to see that the shock absorbers and springs are in good condition, those are the two components of your VW that give it height ... 70% is given by the spring and the other 30% the spring ... most likely it is that your spring already lost tension or melting are modified (cut) or derrepent are those of a coil overs and your suspension (shock absorbers) Semiidura or hard (modified) ... You can also check the rear suspension is higher than standard and this leads to your vehicle is lower in the front ... What are motor supports and box does not give you the height of the vehicle itself ... I hope to help you with these humble comments ... SLDS .... Jorge. :lol:
