Seat Ibiza 1.4 Gasoline 97
17 years 7 months before #3081 by manual-mecanica
SEAT IBIZA 1.4 GASOLINA 97 Published by Manual-Mecanica
Hello, how would I like someone to give me a hand, I have a Seat Ibiza Gasolina 1.4 of the year 97, one day I have a very large reduction of marches and the engine suffered a lot, since that day it does not take more than one hundred, the gearbox I have checked it well but the vehicle in authorship does not take much speed.
I would like someone to tell me whether the engine can be opened and repair something, rectify it or something like that, or if it is only a joint, or if you have any manual that I guided.
-You know if there is any computer emulator to connect the car and make a diagnosis
17 years 7 months before #3083 by manual-mecanica
Manual-Mecanica Answer on the Re: Seat Ibiza 1.4 Gasoline 97
Hello consultation, the car is working if it is working well, you do not have a repair, I stopped me when you reduced the change left the knit send to check with a mechanic of your confianity, ok a Apro
17 years 6 months before #3341 by manual-mecanica
Thanks Maatt 1210. But I would like it to walk better since 100 does not pass, check the gearbox and all “ok” all gears are in place.
The problem is from the engine, but I would like to know, before taking out the engine possible breakdowns of this engine because more than one person will have happened to me and if it is very difficult to rectify it in case you need it
17 years 6 months before #3346 by manual-mecanica
You have a light check light if you do not check the distribution strap phase that possibly has skipped a dandelion in advance delay and that is why you do not walk you or if you do not put the computer and make you make the initial parameters to take all the initial characteristics and if you are in recovering it eliminates it.- Greetings Alf
17 years 6 months before #3364 by manual-mecanica
Hello. It seems to me that what you have folded has been some valve, so the car will be working with 3 cylinders and that is why it lacks strength. Greetings
