Problems with a Jeep Grand Cherokee
13 years 9 months before #30772 by manual-mecanica
Problems with a Jeep Grand Cherokee published by Manual-Mecanica
Hello, I have a problem is when it accelerates while I am walking a buzzing is heard but the noise disappears in descents and in curves but when I accelerate again the noise appears like a buzz and when it stops I accelerate and there is no noise but only when I am in motion.
Change differential oils greased because it seemed to be something of the body but remains the same.
If anyone knows or wants to think please help
13 years 9 months before #30775 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with a Jeep Grand Cherokee
For me they are recaptured the crossbows ... or your masses !!
13 years 9 months before #30793 by manual-mecanica
Hello J-Rdiaz.
Check the differential, there is probably wear that can be solved with a small adjustment and also check the masses, as Jazuke tells you. Luck.
Miguel
13 years 9 months before #30824 by manual-mecanica
It seems to me because of your data that your problem is in piñon rulee but you should change those of the crown also in case I did not understand you by pulling cusondo loosen goes away or is less in a fixed one that you would have to start there. I agree with the previous 2 colleagues
13 years 9 months before #31000 by manual-mecanica
Hello, apart from thanking them for your councils, I tell you that it was a crosshead, thank you very much.
