Consultation for maintenance
13 years 9 months before #30764 by manual-mecanica
Consultation for maintenance published by manual-mecanica
Hello Friends of the Forum, greetings I have a Hiunday Verna car 1.5 year 2010 Diesel Motor with Camon Raid (CRDI) my query, those brand liquid products that empty the oil pond, are effective to maintain the injection system, and Camom raid without having to disarm, to perform it, manually. My car has 45000klm. To date and how often is it necessary, repeat the prosecutor ?? Oh Algien of the forum, you can send me information such as performing maintenance in a special way, which corresponds to the ATTE injection system. Luis
13 years 9 months before #30865 by manual-mecanica
Manual-Mecanica Response on the Re: Maintenance Consultation
Generally, car manufacturers recommend not using additives, I advise you, that you check your owner manual in this regard.
Personally, I tell you that Diesel Common Rail engines are electronically controlled, so they do not require maintenance, in case of damage the injector is changed and only some specialized laboratories such as Bosch make repairs of them.
Silo that you need is to maintain your car more frequently change the fuel filter. If you bring purgal purge system, 15 days, if not with the change of filter it is sufficient.
I hope I have helped you
greetings
