consultation
13 years 9 months before #30692 by manual-mecanica
Consultation published by Manual-Mecanica
Hello friends again for your help ...... I tell you I have an Izusu trooper 2.6 4ZE1 engine that Avia starts to throw water through the butt packing, disarms it to replace the packaging. And I found the surprise that the butt is very damaged (eaten) My question is whether I would not find a cylinder head of the same engine, the 4ZE1 cylinder head will serve?
, 4ze1 -4ZD1 ...
13 years 9 months before #30781 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation
If the lid is aluminum, it is filled with aluminum with MIG /TIG welding and it looks good if the one who does the work knows about the subject, another thing that you can do for trouble is to fill it with poxiline, in Argentina it is called that, it is from poxipol, Googlea, it is something very hurry Aluminum paste and the other an iron/steel paste, greetings !!
13 years 9 months before #30826 by manual-mecanica
You can fill it after the flat brush are equal to new safety you make a hydral proof to see that it has no pores that have welding losses
