Peugeot 307
13 years 9 months before #30611 by manual-mecanica
Peugeot 307 published by Manual-Mecanica
The problem is when it accelerates little by little, the engine has a remained as if it were a lack of gasoline, it is more explosions by the admission. Fuel pressure 3.3 bar, 15cm3 injector flow at 1000rpm and 4 milliseconds for 1 minute. I don't have any error code.
13 years 9 months before #30625 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 307
They can be the injectors, the MAP sensor, the bad benzine filter or the Catalico that is obstructed.
Rabiza also the air filter, spark plugs and spark plug wires.
