Does not turn a board and does not start Pontiac Sunfire 97
13 years 9 months before #30559 by manual-mecanica
Hello, how about greetings for everyone, I ask your help to fix Pontiac Sunfire 97 2.4L 16V. What it does is the following:
when putting the key in ignition (or switch as it is commonly said) it does not turn on any travler indicator (oil, battery, Theft, Check Engine), it is heard that the gasoline pump is loaded and I start it, it goes, it starts two seconds and turns off, I repeat them again does not turn any indicator of the board already checked.
I thank you in advance thanks.
13 years 8 months before #31388 by manual-mecanica
The board communicates with the key by sending a return voltage, so if the board or instrument panel is damaged, the car does not start, it is necessary
