Order Ford Ka 98
13 years 9 months before #30509 by manual-mecanica
Manual-Mecanica Response on the Re: Order Bujias Ford Ka 98
Ok understood. . . I understand the fusca but you knew that this classic design a man (to call him in some way) that caused a genocide in the twentieth century and called Adolf Hitler. . . What do you expect from such a person? . . . Well, do everything to the setback to take the opposite.
But I follow in my 13 the order of the "standard" spark plugs (which becomes the order of the cylinders) is: 1-3-4-2, and until a Ferrari engineering, Maclaren, Redbull I am written the opposite. . . I tell you because I have a Ford party and the ignition system is the same as the Ford Ka as mentioned Leandro H.
13 years 9 months before #30510 by manual-mecanica
Greetings, the order of ignition in a 4 -cylinder engine is normally 1,3,4,2 (except for certain cases such as the beetle), although the engine is arranged linearily 1,2,3,4 the ignition sequence is not, in the case of the KA it has two coils integrated into a only piece, call for the example of coil A and B, they are always activated in sequence A, B, B, B, B, B, B, B, B, B. The connection of the spark plugs to coil A is 1 and 4, and in B is 2-3, in such a way that the sequence 1,3,4,2 is met. To discover what is the A or B coil, try to measure the resistance of it where the connected cables go, where you get impedance reading that is one of the coils.
13 years 9 months before #30640 by manual-mecanica
I thank the information received and I am pleased to have the Ford Ka walking perfectly. I took the solution of someone who commented something very simple such as testing the cables with the disconnected battery and the simple detail of pushing the pins of the back of the plug (of the injectors).
I really congratulate him for the detail contributed,
they not only helped me, but save me a
electronic diagnostic workshop A strong hug
