Order Ford Ka 98
13 years 9 months before #30484 by manual-mecanica
Order Ford Ka 98 Bujias Published by Manual-Mecanica
Hello, I would like to know if the order of the spark plugs is 1-2-3-4 starting from the side of the crankshaft pulley. It is a Ford Ka 98
NAFTA base. THANK YOU!
13 years 9 months before #30487 by manual-mecanica
Manual-Mecanica Response on the Re: Order Bujias Ford Ka 98
The order is 1 - 3 - 4 - 2, but to change the spark plugs it does not matter, it has it when you take away the cables or repeat the lid of the ofco.
13 years 9 months before #30488 by manual-mecanica
The problem is that the K does not have a high voltage distributor.
This model has a double coil with four outputs (one for each cylinder)
is arranged from to pairs 1-4 and 2-3
13 years 9 months before #30505 by manual-mecanica
Have if we find out. . . Delco, distributor and double coil is the same, more. . . The distribution is what it will be for more than 150 years 1-3-4-2 not varied in any gasoline engine. . . It is elementary mechanics. . . It doesn't matter the brand. . . Porsche, Ferrari, Seat, Renault, etc. . .
If what you want is to change the spark plugs you simply take the cable from a replacement and repeat the operation. . . And so not the liars, is that it has no more difficult. . .
13 years 9 months before #30507 by manual-mecanica
Excuse me but the classic fusca the ignition order is 1432. With respect to the cables you say that you have two coils with two cables connect a 1y4 coil and the other 2y3 starts if it presents you fail or simply does not start changes the cables or the coil that connected the 1y4 place the 2y3 and the other in the 1y4. luck!!
