The blazer gets hot
13 years 11 months before - 13 years 11 months before #30332 by manual-mecanica
The Blazer is overheating. Posted by manual-mecanica
My Blazer is overheating, and I've already replaced the water pump and thermostat, and I've checked the radiator and it's fine. What could it be?
13 years 11 months before #30341 by manual-mecanica
Manual-Mechanics' reply on the topic Re: Blazer overheats
Check if the electric fan is running; if it's not, check that the viscous coupling is working. If everything is okay, check that the oil is not emulsified, that there is no oil in the water, and that there is no compression in the water system. Any of these characteristics being positive indicates a problem with the head gasket.
13 years 11 months before #30382 by manual-mecanica
Oh, thanks, I'll check it out. Hey, but which one is the bisque and the electro?
13 years 11 months before #30385 by manual-mecanica
Sorry for the abbreviation, the electric fan is the fan that works by electricity and the viscous fan is the fan that works directly with the water pump and is located opposite the radiator.
13 years 11 months before #30396 by manual-mecanica
Great, thank you, I'll check it out.
