Blazer is heated
13 years 9 months before - 13 years 9 months before #30332 by manual-mecanica
published by Manual-Mecanica is heated
The blazer is heated and I already changed water pump and the thermostat and check the radiator and what could it be?
Last edition: 13 years 9 months before by .
13 years 9 months before #30341 by manual-mecanica
Manual-Mecanica Response on the Re: the blazer is heated
Czech if the electro leaves, if it does not bring Czech that the Biscose Trave, if everything is good, Check that the oil is not emulted, that there is no oil in the water and that the comprehensive is not in the water system, any of these characteristics that is positive is the packaging of the cylinder head.
13 years 9 months before #30382 by manual-mecanica
Thank you to checar hey but what is the biscose and the electro
13 years 9 months before #30385 by manual-mecanica
Sorry to abbreviate, the electrventillator is the fan that works by current and the bisco is the fan that works directly with the water pump and is faced with the radiator.
13 years 9 months before #30396 by manual-mecanica
very well thanks I'm going to checar
