Platina 2004
13 years 11 months before #30290 by manual-mecanica
Platina 2004 Published by Manual-Mecanica
Hello friends, how are you. I have a 2004 plain that when I turned it on and there are times that makes one or two explorations and I was washing a mector, they created the time kit and made a good tuning. The problem is that they are just taking wool and it doesn't look good for you very much if someone gives me a good north of the problem
thanks friends!
13 years 11 months before #30298 by manual-mecanica
Manual-Mecanica Response on the Re: Plate 2004
It is fine during the day or the engine is irregular and moves? How is the force going? Or is it just when I turn on? If it is only when I turn on the crankshaft captor who is mounted on the gearbox in the shell, take it out and clean it that so rusty is the dentate of the inertia steering wheel if it is very rusty lid it, and try to see how you are doing, eye if you are going to change the crankshaft captor only replace it for an original one the alternative does not work.
