GRAndcherakee 1993 A/C drainage
13 years 11 months before #30245 by manual-mecanica
Manual-mechanical response on the topic Re: A/C DRAIN OF THE 1993 GRANDCHEROKEE
Look, that truck does have a hose, it's just that some person or mechanic takes it off and doesn't put it back on. Look under the right seat for a small plastic tube. See which way it goes; you'll see it on the right side. Then look for it on the right side of the engine. You'll see it, but not clearly enough. There should be a metal cover or a cloth insulator underneath it, and it's blocked
13 years 11 months before #30246 by manual-mecanica
Or, from the inside, try inserting a screwdriver so you can see exactly where it comes out, and you'll find it faster. To remove that drain itself, you have to remove the evaporator, and that requires lowering the dashboard and being very careful with the wires, but it's easier the way I explained
13 years 11 months before #30247 by manual-mecanica
Okay, I'll dedicate some more time to looking for it. This issue has been going on for about four months. Before, it was leaking quite badly. I've always maintained my other cars from the inside with water pressure, but there's no access to this SUV. The system is completely sealed because all the equipment is inside the cabin. Thank you again, and I'll let you know the results. A hug from afar and best wishes for success in this new year. We'll be in touch.
Eduardo
13 years 11 months before #30248 by manual-mecanica
Okay, that's the other option I didn't want to consider, but I've noticed it's not necessary to take anything apart. In fact, I wouldn't do it because I hate internal noises in the car, and removing the dashboard would only create more noise. I'll let you know in the next few days what happens with your advice. Hugs
13 years 11 months before #30253 by manual-mecanica
ok friend still from Venezuela greeting
