Hello, I sres from the Mechanical Manuals forum, I have a problem with my car, since I bought it I could easily turn it on but a problem of reheating of the engine and the car went out, a pipe was changed where refrigerant circulates to the engine through the radiator, ok, then I turned on but I could not accelerate it a lot, and drown until I turned off I turned on the light (Power). Checking the engine, the battery was over, the battery of another car was changed because I was injured, the key passed and it does not turn to me sound only the start as if it was missing the explosion so that normal garment, a taxi driver told me to wet a gas cloth and put it to the air input system where the butterfly is located, place it and the car ends up. Hard as 30 seconds, the person who conducts a taxi that can be the bomb that does not send enough power to the injectors, or the injection system that will review it, now I have been checking it, the pump is fine and the ignition coil, the fuses are all right, the consputer well, and keep giving me the same problem, and I do not know what to do what I do and I have to apply the trick of the gas For a mechanic but I want to be sure of what happens there and I can't move it I have to take it to crane in that case, sorry for the discomfort for reading this comment but I hope they help me with this case thanks .......
