Oxide Motor Block
13 years 10 months before #29867 by manual-mecanica
Oxide Motor Block published by Manual-Mecanica
Hello good community, I would like to know how to remove the oxide from a block that I have, because I want to start restoring it, which is good to remove it, I hope your help thank you very much chau
13 years 10 months before #29881 by manual-mecanica
Manual-Mecanica Answer on the Re: Oxide Block Motor
There are oxide stirring in the market that work quite well, the other is with passance to sandpaper and drill, but if you make it work in a week, there will also be paintings that cover and eliminate oxide. The other is to sand it but only on the outside or you even think
