I introduce myself
13 years 7 months before #29826 by manual-mecanica
I present myself published by Manual-Mecanica
Wenas noxes I am a canary and I have an Opel Cors
13 years 7 months before #29829 by manual-mecanica
Manual-Mecanica Answer on the Re: I present myself
Good and greetings from another canary
I had a Corsa the City of 86 I don't know if it will be the same model, I also change the engine several times and something similar happened to me. Check the dough cables that go to the chassis the screws where they are fixed.
Assuming that the battery is not half load etc.
greetings
13 years 7 months before #29830 by manual-mecanica
The screws if they are clean and the battery is new and the emos tested giving him a direct max of another car and nothing spark plugs do not release spark
13 years 7 months before #29840 by manual-mecanica
If you do not have a spark, the main suspect is the firing posiicon sensor (Iman Czech captor who is working) if it works, make sure that the dentate where he reads is not oxidized, if that is fine then you check the coil that is usually a can in these cars.
13 years 7 months before #29853 by manual-mecanica
Okk, he will see that I change that that turns around and the spark plugs come out I do not remember what is called and tmb have told me that it can be the decoded key
