VW Sedan (Vocho)
13 years 10 months before #29766 by manual-mecanica
VW Sedan (Vocho) published by Manual-Mecanica
I want to know if the VW Sedan that I want to settle is fine, his engine could tell me that I have to check and if they can send me better images since I don't know anything about mechanics
13 years 10 months before #29794 by manual-mecanica
Manual-Mecanica Response on the Re: VW Sedan theme (Vocho)
Apart from seeing you have to listen and smell, feel the walk, I recommend that you carry a better mechanic.
13 years 10 months before #29909 by manual-mecanica
In the VW you just have ke checar the bench of the Sigual on the engine pulley The below that carries the band to the generator only put the car in neutral and pull the pulley towards the attract and forward if it is played that I have to say that the engine is already in the last ones. A little bad the engine, another thing verifies if it does not throw oil but regularly that is packaging and it is not very expensive greetings Espro serves you this greetings
