Radiator leak
13 years 10 months before #29663 by manual-mecanica
Radian leak published by Manual-Mecanica
Hello everyone:
I have a leak in the union of the plastic mouth to the radiator and the radiator itself (below). I have heard that there is a liquid, that mixed with the antifreeze is able to plug the pore. It's true? Another solution?
13 years 10 months before #29674 by manual-mecanica
Manual-Mecanica Response on the Re: Radiator Fugue
Good Jolumon
what you say about the liquid I don't know if I have used red powders that are thrown into the radiator and are called cover and if the leak is not large, but in the area where you say I have never tried it.
But it tries but with some type of nural there are monters for different applications.
It supplies
13 years 10 months before #29681 by manual-mecanica
The radiator lightners work but only for a while, they are made in the water, you take out the thermostat before, and they work if it does not work and the pore is not large you can provise with silicone or with liquid wool, or with poxipol ahy amount of products, as the partner says
13 years 10 months before #29682 by manual-mecanica
There is no remedy ...
I have put a lidfugas boat of the Forté brand, they have told me that it is fucking?
There I have it in progress ... let's see ...
I'll tell you.
However, thanks
13 years 10 months before #29705 by manual-mecanica
Well ... yes, it works !!
Now, it only remains to know how long it will last ...
to another, Chao.
