Lack of power Hyundai Santa Fe 2008 CRDI
13 years 10 months before #29659 by manual-mecanica
Lack of power Hyundai Santa Fe 2008 CRDI published by Manual-Mecanica
Hello friends I have a Santa Fe 2008, and I have power problems, it stays at the exits when waiting for the green light in the semaphors in addition to an excess of fuel consumption. He was taken technical service and have had all the engine electronics and transmission and have not encountered problems, so they determined to disassemble the turbo to review due to a strange noise.
Do you have an experience in this type of failure?
Grateful for your comments ....
13 years 10 months before #29735 by manual-mecanica
Manual-Mecanica Response on the Re: Lack of power Hyundai Santa Fe 2008 CRDI
Hello friend and have you not given you the turbo? Does it make you a lot of smoke?
13 years 10 months before #29761 by manual-mecanica
I still do not have the result of the turbo stat
13 years 10 months before #29763 by manual-mecanica
Hello friend, I had a similar problem we did the check and the result came out that the air flow sensor must be replaced.
13 years 10 months before #29765 by manual-mecanica
Thank you very much for your Kuhner help, I will try with the car sensor of a friend, to compare the result.
Later I tell you ...
