Toyota Hilux 98, as part and dies
13 years 10 months before #29516 by manual-mecanica
Toyota Hilux 98, as part and dies published by Manual-Mecanica
Hello, I need this Toyota Hilux truck year 98,
I have reviewed it complete, I made a scanner and I got out that it has a burnt fuse because it does not reach energy to the computer because it does not read anything even the battery voltage and the manual that I have in English already sorrows I am with the Spanish,
I am thinking that it can be the computer but how do I see that?
Because I turn the key and how is it going to leave the key and stop.
13 years 10 months before #29517 by manual-mecanica
Manual-Mecanica response on the Re: Toyota Hilux 98, as part and dies
I do not understand what you mean, it parties and dies if the scanner t says that it is an ancient and check fuse one by one also if the computer would be badly not to connect with the scanner it could be a failure with the coil or something or the spark plugs because suppongo
that goes away hahaha that you are lucky
13 years 10 months before #29518 by manual-mecanica
Hello friend for what I have understood the first rounds of the engine it seems that it will start. Or it is surely doing well for seconds as if I wanted to start. That friend I think you have decoded you
13 years 10 months before #29553 by manual-mecanica
Hello, I infinitely appreciate the orientation and I tell you:
that a cable had been cut inside in one of the 4 cables that went to one of the two coil that has the Hilux only comparing the voltages that went to the coils I found it (with the given contact) and in relation to the scanner it does not have the update it needs to diagnose a Toyota Hilux.
MUCH OBLIGED.
LUCK
